tom_abramov
Level V
Check Display box existence by JSL
Is there some function to check whether exists certain display box by number/title?
For instance:
dist = Distribution(Continuous Distribution( Column( :weight ) ));
Exists((dist<<report)[OutlineBox(10)])// will return return false
Exists((dist<<report)[OutlineBox("ABC")])// will return return false
Thank you.
Re: Check Display box existence by JSL
See this example for a user function.
Names Default to Here( 1 );
exists = Function( { db expr },
	Try(
		db expr;
		1,
		0
biv = dt << Bivariate( Y( :weight ), X( :height ), Fit Line );
bivr = biv << Report;
If( exists( Expr( bivr[OutlineBox(1)] ) ), "I'm here!", "Where did I go?" );
If( exists( Expr( bivr[OutlineBox(100)] ) ), "I'm here!", "Where did I go?" );
	Try(
		db expr;
		1,
		0
