'Display Options' is no longer one of the menu items when i click on the red triangle of a chart. How do i find the display options menu for a chart? Is there a way to update my chart preferences so that i can retain my settings? I searched the preferences but nothing is coming up.
There are many different chart platforms in JMP. Which chart are you specifically asking about? Also, what version of JMP are you referring to where you used the Display Options you are talking about?
Community support for versions < 17 might get worse:
current JMP licenses are just valid for JMP 17 (via license file) and 18 (via lixense manager). Unfortunately, no longer license keys which work for previous versions :(
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '768236' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '768236') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '768236') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
