alexg
Changing confidence level of regression parameter
Under the Fit Y by X or Fit Model platform, JMP by default gives 95% CI for regression parameters b0, b1, etc.  Is there a way to change the confidence level to, say, 90%?
Thanks in advance.
mpb
mpb
In the Fit Model dialog, click the red triangle next to Model Specification and choose the Set Alpha item.
ron_horne
hi Alex,
once you ask for the linear fit all you need to do is click on the red triangle of "linear fit" and select "set alfa level" to whatever you want.
make sure that "confid curve fit" is also selected in that menu.
hope this is what you wanted.
alexg
Thanks for your reply.  However, that is not what I am looking for.  I am referring to the CI of the parameter estimates of intercept and slope. In the parameter estimate box, by right clicking, one can choose to display 95% CI column for the regression parameters.   My question is:, how do I change it to 90%?
mpb
mpb
alexg
Thanks.  I appreciate your help.
