DrDress
Change order of categorical columns in graph
Hi
I'm new to the forum. I'm making a graph which has many rows containing a column of real numbers "measurement (mm)" and one of categrorical labels "Height". I want to have the graph divided into groups of each height. But the order of the height is not desireable. See picture. Is there a way to change the order of the grouping with nominal data labels?
Re: Change order of categorical columns in graph
Add the column property Value Order and arrange the Height levels the way that you want. Right-click the Height column header and select Column Properties. Then select Value Order.
This way is a global change so that you do not have to re-order the levels every where that they might appear (local change).
