Agustin
Change graph background colour between reference lines
Hi, I have a scatter plot with a line of best fit to which I've added 2 reference lines to the x-axis.
Is there an easy way of changing the background of the area between both reference lines to light-grey.
Thanks!
Re: Change graph background colour between reference lines
One option is to use some scripting and add graphic script
gb = dt << Graph Builder(
	Variables(X(:weight), Y(:height)),
	Elements(Points(X, Y, Legend(3))),
		Dispatch(
			"height",
			ScaleBox,
			{Add Ref Line(65, "Solid", "Black", "", 1),
			Add Ref Line(55, "Solid", "Black", "", 1)}
rep = gb << report;
framebox = rep[frame box(1)];
framebox << Add Graphics Script(
	Transparency(0.5);
	Fill Color("Gray");
	Rect(X Origin(), 65, X Origin() + X Range(), 55, 1)
		Dispatch(
			"height",
			ScaleBox,
rep = gb << report;
	Transparency(0.5);
	Fill Color("Gray");
You can also use a reference region. The region is independent of the lines. You can use either one or both of them.
	Variables( X( :weight ), Y( :height) ),
	Elements( Points( X, Y, Legend( 3 ) ) )
rpt = gb << Report;
rpt[AxisBox(2)]
	<< Add Ref Line( 55, "Solid", "Black", "", 1 )
	<< Add Ref Line( 65, "Solid", "Black", "", 1 )
	<< Add Ref Line( { 55, 65 }, "Solid", "Green", "", 1, 0.25 );
