UserID16644
Level V
Save Predicted using JSL
Hi all,
How can I save the Predicteds formula in a Bivariate plot using JSL?
Re: Save Predicted using JSL
Here is an example
obj = dt << Bivariate( Y( :Weight ), X( :Height ) );
obj << Fit line( {Save Predicteds} );
Taken from the Scripting Index, with small modification
Here is an example
Here is another way to show the flexibility of Bivariate.
obj = dt << Bivariate( Y( :Weight ), X( :Height ), Fit Line( 1 ) );
obj << (Curve[1] << Save Predicteds);
