aallman
Change contingency table formatting
When I do a contingency analysis, the numbers in the table are too big for the column and they end up overlapping. I can't figure out how to adjust the size of the columns or the text formatting so that this doesn't happen.
Re: Change contingency table formatting
I tried various actions, like Control-click, but there is either no menu or the menu does not provide a command to change the format or size of the cells. I looked at the protocol for the CrossTabBox object. The only messages that might help are << Set Height and << Set Width, but these messages had no effect.
Maybe someone else knows of a solution. If there isn't one, then I suggest that you enter a request in the JMP Wish List. (Be sure to search first because someone else might have already entered such a request and then you can vote for it.)
