mperuffo
Change MySQL ODBC Driver version
I am trying to connect JMP to a MySQL database but JMP give me only the latest version of drivers even if on my machine I have the old version that is the only one compatible with the database.
I have installed the correct drivers and as you can see on the attached picture on the Admin tools I have the the 5.1 version that is compatible and I can connect the database to the system.
However when I use JMP I have only the 8.0 that is not compatible with the database.
 Any idea how I can use a different drive version within JMP?
Re: Change MySQL ODBC Driver version
I think if you have 64bit JMP it will only look for drivers you can find from 64-bit ODBC Data Source Administrator. I'm not sure if there are any ways to look for 32bit drivers with 64bit JMP.
I think JMP support maybe be able to help you out with this one. You can contact them by sending email to: [email protected]
Could you be comparing 32bit and 64bit drivers by accident?
mperuffo
On the admin tool I am on the 32 panel and I have installed only the 32 version of mysql drivers
Jeff_Perkinson
@jthi is correct. The ODBC driver must match the "bitness" of the application using it. So, since JMP is 64-bit, the ODBC driver must also be 64-bit.
It looks like you might be able to download a 64-bit MySQL ODBC driver here.
-Jeff
mperuffo
Thanks, I installed the 64bit version of the same drivers and now I can find the driver on the JMP panel too.
