nadia
Change JMP language from German to English
Dear all
My JMP is intalled in German - I would prefer it in english as all the manuals and helps are in english... It would be a lot easier to find my way trough the explanations.
The solutions I found in this forum were for older versions of JMP. I have JMP11 (on Windows 7).
Thanks for your help!
Craige_Hales
Re: Change JMP language from German to English
Does setting the language preference do what you need?
Craige
Craige_Hales
Craige
nadia
Thank you so much! The commands are in english now! The explanations for Version 9 I've read in the forum were so complicated... and now it's so easy.
