nadia
Change JMP language from German to English
Dear all
My JMP is intalled in German - I would prefer it in english as all the manuals and helps are in english... It would be a lot easier to find my way trough the explanations.
The solutions I found in this forum were for older versions of JMP. I have JMP11 (on Windows 7).
Thanks for your help!
Re: Change JMP language from German to English
Does setting the language preference do what you need?
nadia
Thank you so much! The commands are in english now! The explanations for Version 9 I've read in the forum were so complicated... and now it's so easy.
