JustineK
Cast selected columns into roles not showing
I have a trouble with JMP16, hopefully someone has encountered and overcome this problem.
While choosing commands, Cast selected columns into roles in Multivariate and correlations, the selected options are invisible. In other words command select the columns into roles, when i click on column name, then click Y,columns, the option doesn't display at all. Surprisingly it seem to invisibly select the names, when i proceed with OK, the output comes out.
Your are welcome to share with me, in case you have some suggestions.
Thank You
Thierry_S
Re: Cast selected columns into roles not showing
Hi Justin,
I had a similar odd behavior when I upgraded my PC to a more powerful one with a GPU. Have you tried to disable the Hardware Acceleration option in the Preferences > Windows Specific > Enable Hardware Accelerated Graphics (Switch Off)?
Let us know if it works.
Best,
TS
Thierry R. Sornasse
