Luna
Capability Indices calculation for Nonnormal Distributions in Percentile Methods
Hi, I would like to figure out how JMP 16 Calculate Ppk in non-parametric method. So I calculate Ppk in R code with the formula in online documentations, but the results are very different. Could anyone help me to understand if it is my calculation error or the documentation?
Luna
Re: Capability Indices calculation for Nonnormal Distributions in Percentile Methods
Sorry I post wrong JMP results, the JMP results are as follow:
frank_wang
Hi Luna
JMP基础统计的结果有吗?看看分位数的结果是否一致。如果公式本身没有问题的情况下。
心若止水
Luna
你好,我简单用R计算了一部分百分位数,和JMP略有差异,但Ppk计算结果差别太大了(R:2.026, JMP: 1.678),可能不是百分位数计算方法造成的误差.
worldwyn
For those having trouble following the conversation...
Hello, I simply used R to calculate some percentiles, which are slightly different from JMP, but the Ppk calculation result is too different (R:2.026, JMP: 1.678), which may not be the error caused by the percentile calculation method .
frank_wang
Hi Luna
考虑到基础统计量计算结果的不同导致最终结果的不同。不知道是否方便讲JMP中基础统计模块的0.99865/0.00135的结果显示一下。方便和R做对比。
具体的方法可在红色三角形中选择option-->客户定制。
心若止水
Luna
Hi Wang,
Sorry for reply so late, I calculate the P0.99865 and P0.00135, the result from JMP and R are still very close.
worldwyn
Are there any results for basic statistics? See if the results of the quantiles are consistent. If the formula itself is not a problem.
