Capability Graphs
I understand that there is a way in JMP to create six capability graphs similar to a "Capability Six-Pack" in Minitab. Can someone tell me how to do that? Thanks.
ian_jmp
Level X
Re: Capability Graphs
Go to 'Help > Sample Data', then press the 'Open the Sample Scripts Directory' and look for 'demoSix QualityGraphs.jsl'. This is actually a rather old script but works fine of course. If you want to make similar things, look at how JMP can build dashboards.
ian_jmp
Level X
