Yes it is possible, you did not add Table data, however here script example:
Capability(
Y( :DATA ),
Spec Limits( DATA( LSL( -2 ), Target( 0.5 ), USL( 3 ) ) ),
Capability Indices Report( 1 ),
Individual Detail Reports( 1 ),
Capability Box Plots( 0 ),
Goal Plot( 0 ),
Dispatch( {"Capability Indices"}, "CPK", NumberColBox, {Select, Visibility( "Hidden" ), Select} )
I guess the easiest way to do it, in case you want to hide some specific area of the chart displayed, it is first create the chart as is, then right click in gray triangle, then select Edit, Show properties.
From there you can click in any area of the displayed information that you want to hide, after selecting it then go to Visibility and choose Hidden.
Regards.
