Justin_Bui
Cannot use Design space profiler function in JMP 16.2
Hi all,
I've just attended a great webinar call  "Design experiments to be robust to input variation" & learn about new JMP tool call Design space profiler to setting spec limit for my factors.
But when I try with my JMP. There is no option like that in my software.
Do you know why & how can I use this?
I'm using JMP 16.2
Thank you all
Re: Cannot use Design space profiler function in JMP 16.2
It is a new feature in JMP 17. It is not available in previous versions of JMP.
Jeff_Perkinson
An upgrade to JMP 17 is complimentary for most licenses. Contact the JMP software administrator at your organization. They were recently sent instructions for how to get JMP 17.
If you have trouble finding your JMP software administrator you can contact JMP Tech Support ([email protected]) and they can help put you in contact with them.
-Jeff
Justin_Bui
Thanks Mark!
