Yajing
Cannot rename Columns by Select-And-Click in JMP15
In JMP15, it Cannot rename the columns by Select-And-Click operation any more, seems like we can only to double click the colomn name and open the comlumn info dialogue to rename. It is not so convinient!!! can some one know how to come back to Select-And-Click way?? Thanks.
Re: Cannot rename Columns by Select-And-Click in JMP15
Selecting the column and simply typing the column name works for me with 15.2.1.  What version are you using?  One thing to keep in mind is it wont work if one or more rows are also selected.
