lala
Level IX
Can the width of the X-axis of the grouped graphics be set separately?
For example, after I draw the graph like this, the widths of these two x-axes are set to be different.
dt=Open("$SAMPLE_DATA/Big Class.jmp");
d2=dt<<Summary(Group(2,3),sum(4),Freq("0"),Weight("0"),Link to original data table(0),statistics column name format("column"));
Column(d2,3)<<set name("S");
d1=dt<<Summary(Group(3),Freq("0"),Weight("0"),Link to original data table(0),statistics column name format("column"));
d2<<Update(With(d1),Match Columns(sex=sex));Close(d1,nosave);
p1=d2<< Graph Builder(
	Size(480, 495),
	Variables(X(:height), Y(:age), Group X(:sex), Color(:S)),
	Elements(Bar(X, Y, Legend(4)))
15 REPLIES 15
Level XIII
Re: Can the width of the X-axis of the grouped graphics be set separately?
you can split the height column in two parts:
... and generate 2 adjacent plots:
Names Default to Here(1);
dt << Summary(
	Group( :age, :sex ),
	Sum( :height ),
	statistics column name format( "column" )
New Column( "height M",	Formula( If( :sex == "M", :height ) ));
New Column( "height F",	Formula( If( :sex == "F", :height ) ));
Graph Builder(
	Variables( X( :height F ), X( :height M ), Y( :age ), Color( :N Rows ) ),
	Relative Sizes( "X", [360 237] ),
	Elements( Position( 1, 1 ), Bar( X, Y ) ),
	Elements( Position( 2, 1 ), Bar( X, Y ) ),
		Dispatch( {}, {:height F}, ScaleBox, {Max( 800 )} )
unfortunately, the color in the plot is unexpected: same color for both sexes ?!
seems that color is taken from rows without values in the column which is used for the response axis.
-> interesting / important finding!
lala
Level IX
Thanks Experts!
Level XIII
So, in addition, either split color or the age axis:
Graph Builder(
	Transform Column( "age_F", Nominal, Formula( If( :sex == "F", :age ) ) ),
	Transform Column( "age_M", Nominal, Formula( If( :sex == "M", :age ) ) ),
	Size( 433, 323 ),
	Summary Statistic( "Median" ),
	Graph Spacing( 4 ),
	Variables(
		X( :height F ),
		X( :height M ),
		Y( :age_M, Combine( "Merged" ) ),
		Y( :age_F, Position( 1 ), Combine( "Merged" ) ),
		Color( :N Rows )
	Elements( Position( 1, 1 ), Bar( X, Y( 2 )) ),
	Elements( Position( 2, 1 ), Bar( X, Y( 1 ) ) ),
		Dispatch( {}, {:height F}, ScaleBox, {Max( 800 ), Inc( 100 ), Minor Ticks( 0 )} )
With the ability to scale the x axes independently, you also get the "duty" to meaningful ranges (= same range) for the 2 color scales.
Level XIII
A much better way: via page
- independent x axes
- synchronous y axis scale - via  Link Page Axes( "Y Only" ),
- synchronous color scale
i hope you don't mind the small gap between the plots
Graph Builder(
	Size( 527, 455 ),
	Replicate Linked Page Axes( 0 ),
	Graph Spacing( 4 ),
	Variables( X( :height ), Y( :age ), Page( :sex, Levels per Row( 2 ) ), Color( :N Rows ) ),
	Elements( Bar( X, Y, Legend( 7 ) ) )
lala
Level IX
This width is the same.
Level XIII
Oh, yes, you are right. The Range can be adjusted individually, but the width is again forced to be the same.
Then I fear you need the lengthy code.
let's see what other users suggest ...
lala
Level IX
Thanks Experts!
I'm using this script.
How can we obtain this subset by following the step of taking a screenshot, by hovering over the graphic or clicking on it?
dt << Summary(
	Sum( :height ),
Graph Builder(
	Size( 433, 323 ),
	Graph Spacing( 4 ),
	Variables(
		X( :height F ),
		X( :height M ),
		Color( :N Rows )
lala
Level IX
I tried such code and could only succeed by clicking on the image "F" on the left.
d1=dt << Summary(
	Sum( :height ),
p2=d1<< Graph Builder(
	Size( 433, 323 ),
	Graph Spacing( 4 ),
	Variables(
		X( :height F ),
		X( :height M ),
		Color( :N Rows )
frame=(p2<<report)[FrameBox(1)];frame<<Set Graphlet(Picture( current data table(dt);d2=dt<<Subset(Output Table("B00"),Selected Rows(0),Rows(dt<<Get Selected Rows()),Selected columns only(0));  ),Reapply(1));
Thanks Experts!
Level XIII
you applied the hover label script just to the first Framebox:
when you want the same function in all (2) Frameboxes, use xpath to get a list of the Frameboxes and send the message to the list:
fbs = gb << xpath("//FrameBox");
fbs <<
maybe use a Modifier Key to make the creation of the subset less spontaneous : )
actions via mouseover ? - use a modifier Key 👉🔳
