matlag
Can't "evaluate" an expression
Hi all,
I'm once again struggling with a script...
This one builds an expression. It looks ok.
I can even copy and paste it from the log file back to the script window, and if I do so, it executes correctly with expected output.
But I tried Eval(), Eval Expr(), Eval(Eval Expr()), Eval(Parse())... well that last one with even less hope than the others, but bottom line is... I just can't make it work!
ParamsList = {
	{"P1", "Parameter 1"},
	{"P2", "Parameter 2"}
analysis = Expr(Analysis Column());
For (i=1, i<= Length(ParamsList), i++,
	Insert Into(
		analysis,
		Substitute(
			Expr(Transform Column("__Desc__", Formula(__Parameter__))),
			"__Desc__", ParamsList[i][2]||" Median",
			Expr(__Parameter__), Parse(":"||ParamsList[i][1]||"_Q50")
addRowExpr = Expr(Row Table());
Insert Into(addRowExpr, Eval Expr(analysis));
Insert Into(addRowExpr, Expr(Statistics(Median)));
addTabExpr = Expr(Add Table(Column Table(Grouping Columns(:Source))));
Insert Into(addTabExpr, Eval Expr(addRowExpr));
tabExpr = Expr(Tabulate(Set Format(Uniform Format(10,2))));
Insert Into(tabExpr, Eval Expr(addTabExpr));
show(tabExpr);
dtParams = Eval(Eval Expr(tabExpr));
I attach a "Test.jmp" file on which you can try.
The output of the "show" command is:
tabExpr = Tabulate(Set Format(Uniform Format(10, 2)), Add Table(Column Table(Grouping Columns(:Source)), Row Table(Analysis Column(Transform Column("Parameter 1 Median", Formula(:P1_Q50)), Transform Column("Parameter 2 Median", Formula(:P2_Q50))), Statistics(Median))));
And as said: if I copy-paste it back to the script window to execute that output, I get what I want!
So, how do I "evaluate" that expression?
Re: Can't "evaluate" an expression
Using my "Morning Brain" I have come up with:
eval(parse(char(evalexpr(tabexpr))))
which will allow the expression that has been built to execute.
I agree with Ian, the code should work as developed, and I suggest you post the issue to:
     [email protected]
8 REPLIES 8
Just running "tabExpr" will evaluate the expression.
tabulateObject = tabExpr;
Justin
matlag
Hi Justin,
It doesn't work here. I'm on JMP 12.1 if that helps.
What it does is creating a tabulate, but it does not populate the content. I get columns A and B.
I have a single row and the count of A and B.
What is your expected output?  I see a lot of things being generated and placed into lists, but I don't see anything being done with those things.
matlag
Argh!
I understand the problem you have, I uploaded Test.jmp before saving a change.
Here is the right version.
Expected output (by copying in the log the result of the show())
The reasons I'm going with a script like this are:
-The list of parameters in the real application is much longer
-The paremeters will change depending on my input data, but they're always documented.
It is certainly strange that the code does not appear to be fully executable in open code.  The only way that I was able to do it, was to convert your expresion tabExpr into a literal string, and to run it with Eval(Parse().
eval(parse("Tabulate(
	Set Format( Uniform Format( 10, 2 ) ),
	Add Table(
		Column Table( Grouping Columns( :Source ) ),
		Row Table(
			Analysis Column(
				Transform Column(\!"Parameter 1 Median\!", Ordinal, Formula( :P1_Q50 ) ),
				Transform Column(\!"Parameter 2 Median\!", Ordinal, Formula( :P2_Q50 ) )
			Statistics( Median )
Maybe one of the other community members have an idea
ian_jmp
Level X
This is indeed strange, and I haven't added much other than to put the code in one place. I suspect it's related to the use of virtual columns, but needs more investigation.
ClearLog();
dt = New Table( "Test",
					Add Rows( 5 ),
					New Column( "P1_Q50",
						Numeric,
						"Continuous",
						Format( "Best", 12 ),
						Set Values( [32.6, 54.8, 48.9, 28, 51.4] )
					New Column( "P2_Q50",
						Numeric,
						"Continuous",
						Set Values( [9, 7, 8, 6, 12] )
					New Column( "Source",
						Character( 1 ),
						"Nominal",
						Set Values( {"A", "B", "B", "A", "B"} )
ParamsList = {
	Insert Into(
		analysis,
		Substitute(
show(tabExpr);
NewWindow("tabExpr", tabExpr);
NewWindow("Eval(Parse(Char(NameExpr(tabExpr))))", Eval(Parse(Char(NameExpr(tabExpr)))));
     [email protected]
matlag
Hi Jim,
Your solution works indeed! Thanks very much.
I'm contacting support.
