Martin
Can JMP launch an excel.xlsm file?
Is JMP jsl able to "launch" an Excel .xlsm (macro'ed) file, such that it essentially "double clicks" the file to open it and does not try to import it?
I am using an Excel macro for database extraction because it is 100X faster than the JMP ODBC extraction tool and would like my jsl code to run the macro'ed file.
Thanks in advance!
ih
Super User (Alumni) ih
Re: Can JMP launch an excel.xlsm file?
Woops, I missed the file extension in the last line:
/* 	Function: openFileInOSDefault
		Open file in the operating system default program
		Include this once at the top of your script
	Arguments:
		filepath - local path file
openFileInOSDefault = Function({filepath},
	If( Host is( "Windows" ),
		Run Program(
			Executable( "PowerShell.exe" ),
			Options(
				Eval Insert( "\[-Command "& {Start-Process '^filepath^'}"]\" )
			Read function( "text" )
		RunProgram(
			Executable( "/usr/bin/open" ),
			Options( filepath ),
			ReadFunction( "text" )
//Now in your script you can just call the function
openFileInOSDefault("C:\Users\Me\Desktop\test.xlsx")
8 REPLIES 8
See the function
in the Scripting Index
Martin
Thanks @txnelson , but I am not sure this is the answer.  If I do not know where the "Excel.exe:" is kept on someone else's computer, how can I share my script with others?
ih
If you know everyone is on windows or has Powershell installed you can use Run Program to open the file using the default program defined by the OS:
Open a file in the operating system default program
Martin
Let's say I want to open a file called "Test.xlsx" that is located at "C:\Users\Me\Desktop\".  What would the code look like?
I have tried the following but it does not seem to work:
rp0 = Run Program(
	Executable( "Excel.EXE" ),
	Options("C:\Users\Me\Desktop\test"),
	Read Function("text")
ih
Give this a try:
	Arguments:
		Run Program(
			Options(
		RunProgram(
openFileInOSDefault("C:\Users\Me\Desktop\test")
Martin
I get this error, thoughts?
"Start-Process : This command cannot be run due to the error: The system cannot find the file specified.
At line:1 char:4
+ & {Start-Process 'C:\Users\Me\Desktop\test'}
+ CategoryInfo : InvalidOperation: (:) [Start-Process], InvalidOperationException
+ FullyQualifiedErrorId : InvalidOperationException,Microsoft.PowerShell.Commands.StartProcessCommand
ih
	Arguments:
		Run Program(
			Options(
		RunProgram(
Martin
This is perfect and works like a charm!
@ih, thanks for your help.
