lala
Level IX
Can JMP draw this pattern?
Hello!
Draw a horizontal bar chart of height data,
Graph the data on weight.
Superimpose two graphs on one graph.
2022-06-10_22-34-34.png2022-06-10_22-34-34.png2022-06-10_22-12-58.png2022-06-10_22-12-58.png
18 REPLIES 18
lala
Level IX
Re: Can JMP draw this pattern?
Go ahead and ask the experts: can these different forms of the graph be added together?
to
Yes.  Graph Builder can easily do this.
  1. I added a transform column set to the Row() and used it for the X axis
  2. I dragged Height and weight to the Y axis
  3. Moved Weight to the right side axis
  4. Then I went into the axis settings for each axis and removed all tick marks and labels.
Documentation on Graph Builder is in the Essential Graphing document
lala
Level IX
Thank Jim!
I tried to do it, but at step 4 I couldn't figure out how to do it.And I don't know if I'm dragging correctly?
Do not create a Group Y, you need to move the axis to the right,.
lala
Level IX
  • Thank Jim!
  • This time I learned. But tried to change the color of the height .
Right click on the legend entry for the line and select Line Color
lala
Level IX
Thank Jim!
lala
Level IX
After this, how to use different colors for the "weight" bar chart according to the "gender".Does this "needle" shape reflect different colors?
I still need expert help.
lala
Level IX
Thanks Experts!
