Can JMP call a DOS Exe
by dos exe I just mean a standard windows/dos command line app that would run in a xp command window.
18 REPLIES 18
Re: Can JMP call a DOS Exe
I'm running JMP 8 from Windows, and am tantalizingly close to making the above work for me, but I can't quite get there. I have a folder on my C: drive called "mydir" which contains a Windows Metafile called "image.wmf", a small text file called "aaa.txt" and a DOS batch file called "filecopy.bat" which contains the one-line DOS command "copy aaa.txt bbb.txt" (without the quotes). I try running each of the following commands from JMP:
open("\mydir\image.wmf");
open("\mydir\filecopy.bat");
The first of the above commands works exactly as the above reply describes (i.e. it opens the default viewer externally of JMP and displays the image), so it's evidently looking in the right place for the file to open, but the second one simply generates the following error messages:
Unable to open file. Unknown or ambiguous data source.
Tried to open: \mydir\filecopy.bat
Cannot open table in access or evaluation of 'Open' , Open( "\mydir\filecopy.bat" )
Open *###* ("\mydir\filecopy.bat")
Can anybody see what I'm doing wrong here? The file definitely exists, but JMP is evidently having trouble deciding what to do with it. (DOS does know what to do with it, as if I run it from a DOS window it copies the aaa.txt file to bbb.txt as would be expected.)
Many thanks for any help - this would be phenomenally useful to me if I could get it working.
David
mpb
mpb
Change your bat file to say:
copy \mydir\aaa.txt \mydir\bbb.txt
and I think it will work (did for me).
mattf
Level V
On Windows XP, JMP 8.02, this works fine for me:
// clean up possible prior runs
SaveTextFile( "C:\temp\deleteme.bat",
"del C:\temp\deleteme.r"
Open( "C:\temp\deleteme.bat" );
If one tires of the flashing DOS window, JMP 8 adds the terriffic "LoadDll" command and you are off to the races.
http://support.sas.com/documentation/cdl/en/hostwin/61924/HTML/default/accdll.htm
http://msdn.microsoft.com/en-us/library/aa363851(VS.85).aspx
kernel32 = LoadDLL("Kernel32");
kernel32 << DeclareFunction("WinExec", Convention( STDCALL ), Alias "WinExec"),
Arg( AnsiString, "lpCmdLine" ),
Arg( Int32, "uCmdShow" ),
Returns( Int32 ) )
); // return value is greater than 31-> success
SW_HIDE = 0;
SW_MAXIMIZE = 3;
SW_MINIMIZE = 6;
SW_RESTORE = 9;
SW_SHOW = 5;
SW_SHOWDEFAULT = 10;
SW_SHOWMAXIMIZED = 3;
SW_SHOWMINIMIZED = 2;
SW_SHOWMINNOACTIVE = 7;
SW_SHOWNA = 8;
SW_SHOWNOACTIVATE = 4;
SW_SHOWNORMAL = 1;
// some examples
result = kernel32 << WinExec("Explorer C:\temp", 1); // 1=max, 6=minimized
show( result ); // returns 0 -> failure, nonzero -> success
// fire R GUI and bring to front
result = kernel32 << WinExec("Rterm", 1);
result = kernel32 << WinExec("Rgui", 0); // Rgui does not hide
// or, fire R term in background
result = kernel32 << WinExec("Rterm", 0);
// this works fine
result = kernel32 << WinExec("C:\temp\deleteme.bat", 0); // 1=show, 0=hide, result gt 31=success
Best regards,
-Matt
Still no joy, I'm afraid: I've tried changing both the text of the BAT file as suggested and the actual DOS command to include the full paths of both files, but the problem's still there. The following script saves "deleteme.bat" as you'd expect, but then fails to run it:
SaveTextFile( "C:\mydir\deleteme.bat", "del C:\mydir\deleteme.r" );
Open( "C:\mydir\deleteme.bat" );
Tried to open: /C:/mydir/deleteme.bat
Cannot open table in access or evaluation of 'Open' , Open( "C:\mydir\deleteme.bat" )
In the following script, error marked by /*###*/
Save Text File( "C:\mydir\deleteme.bat", "del C:\mydir\deleteme.r" );
Open/*###*/("C:\mydir\deleteme.bat");
Could it be that the BAT file needs to have some property reset for it, or something like that?
mpb
mpb
This works for me: I have a directory called c:\mydir . In it I have a text file called a.txt which contains one line of text: Copy Me. In the same directory I have a batch file called test.bat which contains one line: copy c:\mydir\a.txt c:\mydir\acopy.txt.
I open JMP 8.0.2 and in a script window enter the line: open("c:\mydir\test.bat") and run it.
When I check mydir I find a copy of a.txt called acopy.txt which contains the line Copy Me.
Please try this exact scenario and report back.
(Sorry - I forgot to mention that I did create a file called "deleteme.r" in the same directory beforehand, so the problem isn't that that file doesn't exist.)
No good - I'm still getting the same error message, i.e.
Tried to open: /c:/mydir/test.bat
Cannot open table in access or evaluation of 'Open' , Open( "c:\mydir\test.bat" )
Open/*###*/("c:\mydir\test.bat")
I've checked everything several times over, down to the case of the letters and creating the bat file both from a DOS window and via WordPad.
Many thanks for looking into this, but please don't spend any more time on it now as it has to be something I'm overlooking, though I can't imagine what. I'll repeat the exercise on another machine as soon as I can, and if I find out what's going on I'll report back on this thread.
David
Message was edited by: David Q/R
mpb
mpb
I'm logged into XP as administrator. Wonder if that makes a difference.
The mystery has just been solved - and as was perhaps inevitable, it looks as though I inadvertantly created the problem myself.
When I originally tried this out, I first set up an association (via Windows Explorer | Folder Options | File Types) to enable me to edit BAT files from WordPad, to save myself the bother of opening a DOS window to do it. However, a side-effect of doing that was that JMP simply passed the file to WordPad - so I shrugged, deleted the association again and forgot about it.
Unfortunately it appears that simply deleting an association to a BAT file after it's been created doesn't restore the way that Windows deals with them to what it ought to be - and that caused several new problems, including the one I've reported here.
Internal Support here have just dealt with it by running a registry fix on this machine - and JMP now handles the BAT file exactly as has been described earlier on this thread.
Many thanks to everyone for their forbearance!
