Neo
Neo
Can I get elements in "Group Y" to "Y" in Graph Builder?
The script below generates data similar to my actual data and plots the data in a layout similar to what I would like.
clear log ();
dt = Open("$SAMPLE_DATA/Probe.jmp");
// Combine columns 1
Data Table( "Probe" ) << Combine Columns(columns( :Lot ID, :Wafer Number ),	Column Name( "LotWafer" ),	Delimiter( "." ));
// Combine columns 2
Data Table( "Probe" ) << Combine Columns(columns( :Die X, :Die Y ), Column Name( "[X,Y]" ), Delimiter( "," ));
// Delete columns
Data Table( "Probe" ) << Delete Columns( :Lot ID, :Wafer Number, :Die X, :Die Y );
grouped_cols = dt << get column group( "Responses" );
// Transpose data table // → Data Table( "Transpose of Probe" )
Data Table( "Probe" ) << Transpose(	columns (grouped_cols),	By( :LotWafer, :Process, :Start Time ),
	Label( :Site ),	Output Table( "Transpose of Probe" ));
close (dt, no save);
dt = Current Data Table ();
<< New Column("Mean", Numeric, "Continuous", Format("Best", 12 ), Formula(Mean( :"1"n, :"2"n, :"3"n, :"4"n, :"5"n )));
dt = Graph Builder(
	Size( 570, 458 ),
	Variables(X(:LotWafer, Order By( :Start Time, Ascending, Order Statistic( "Mean" ) )),
		     Y( :Mean ), Group Y(:Label,	Order By( :Process, Ascending, Order Statistic( "Mean" ) ))	),
	Elements( Points( X, Y, Legend( 23 ) ) ),
	Local Data Filter(Conditional, Add Filter(columns( :Label ),Where( :Label == {"30D1_7X100_IL_12V", "30D1_7X100_IL_25V"} ),
			Display( :Label, Find( Set Text( "" ) ) ))),
	SendToReport(Dispatch({},"Mean",ScaleBox,{Min( -0.0000336 ), Max( 0.00004544 ),
			Inc( 0.00001 ), Minor Ticks( 1 )})));
However, I would like the Process name mentioned on the Group Y (i.e. I do not want Group Y section to say, "Label ordered by Process"). As I select more labels on the local data filter (conditional), I would like the Group Y and Y to be populated accordingly.
Even better would be to have the measured parameter "Labels" on the left side "Y" axis while the "Process" names in the "Group Y" and they need to respond to my selection on the local data filter.
How to achieve this in JSL?
Re: Can I get elements in "Group Y" to "Y" in Graph Builder?
Drop the process to this location
You can hide the group title
Might be a good idea to remove min/max from your graph builder script to allow Y-axis to scale as it wants to
Neo
Neo
@jthi . The graph builder part of the script was generated after interactively doing the layout using the Graph Builder. Hence the min/max.
I do not need to hide the group title. I want it to be shown as "New" and "Old" separately (in place of ordered by Process). How to di this in JSL?
Level XIII
Nice idea, use a Data Filter as a Column Switcher with modeling Type Multiple Response :)
To move the Y Group labels to the left right click on the Y Group and select Y Group Edge/Left:
To order the entries by Process, the order column has to be numeric.
OK to put the Process label on top?
Alternatively, you could use different colors to distinguish between old and new value.
:Process << Set Property( "Value Order", {Custom Order( {"Old", "New"} )} );
New Column( "Process2", Set Each Value(If(:Process=="Old",1,2)) );
Graph Builder(
	Show Y Axis Title( 0 ),
	Y Group Edge( "Left" ),
	Variables(
		X( :LotWafer, Order By( :Start Time, Ascending, Order Statistic( "Mean" ) ) ),
		Y( :Mean ),
		Group X( :Process ),
		Group Y(
			:Label,
			Order By( :Process 2, Ascending, Order Statistic( "Mean" ) ),
			Show Title( 0 )
		Overlay( :Process )
	Local Data Filter(
		Conditional,
		Add Filter(
			columns( :Label ),
			Where( :Label == {"30D1_7X100_IL_12V", "30D2_7X20_BDV"}  ),
			Display( :Label, N Items( 15 ), Find( Set Text( "" ) ) )
Level XIII
alternative approach, with std. BigClass  (with sex = Process):
Create an new Label with "_process" appended
perhaps an additional subplot as an indicator for the "process"
Names Default to Here(1);
gb = dt << Graph Builder(
	Size( 437, 413 ),
	Graph Spacing( 4 ),
	Elements( Points( X, Y, Legend( 1 ) ), Smoother( X, Y, Legend( 2 ) ) )
dtStacked =  dt << Stack(
	columns( :height, :weight ),
	Source Label Column( "Label" ),
	Stacked Data Column( "Data" ),
	Output Table( "Untitled 3.jmp" )
dtStacked << New Column( "myLabel",Character,Formula( :Label || "_" || :sex ));
dtStacked << Graph Builder(
	Size( 494, 335 ),
	Set α Level( 0.01 ),
	Summary Statistic( "Median" ),
	Graph Spacing( 4 ),
	Variables(
		X( :name ),
		X( :sex ),
		Y( :Data ),
		Group Y( :myLabel ),
		Overlay( :sex ),
		Color( :sex )
	Relative Sizes( "X", [240 56] ),
	Elements( Position( 1, 1 ), Points( X, Y, Legend( 37 ) ) ),
	Elements( Position( 2, 1 ), Heatmap( X, Legend( 31 ) ) ),
	Local Data Filter( Add Filter( columns( :Label ), Where( :Label == "weight" ) ) )
