efulton
Can I Transfer Information from Curve Fitting Module to Main Table?
Hello!
I have a very large dataset and I want to evaluate the difference between drugs among different groups (eg. I am evaluating the efficacy of a drug within different patients and against four different cancer targets). I was able to gain some helpful information by fitting a Gompertz 4P model to my data using the curve fitting workspace in JMP 17 but I would like to visualize some of the readouts like infleciton point for my different samples. Is there an easy way to transfer that information back into my main data table so I can plot it? Thanks for the help!
Re: Can I Transfer Information from Curve Fitting Module to Main Table?
Save Formulas
or maybe in this case Make Into Data Table (right click on your table box in report) + Join/Update to original table
might do what you are looking for.
Here is example for the join/update.
Starting data
Make into data table
Update (change settings as needed)
