PaleoHunter
Calculations between rows based on conditions
Hey, I'm new to JMP scripting, but somewhat used to python language. I'm trying to achieve the following with my dummy test table below:
1) Cycle through all rows (both before and after the row) and do calculations only on those rows where Cuvette == 11, remaining rows where Cuvette != 11 the "Output" can be set to NA or whatever.
2) The calcuation itself is between two separate rows. In rows with Cuvette == 11, the 850 nm cell of the row has to be divided with the 250 nm cell from the row that meets two conditions:
                   a) Cuvette == 12
                   b) The Pass value has to match up between the rows, e.g. Pass value for cuvette 11 == Pass value for Cuvette 12
Pass 850 nm 250 nm Cuvette Output
1 100 200 11 100/500 = 0,2
2 400 500 11 400/400 = 1
3 300 100 11 300 / 900 = 0.33
1 700 500 12 NA
2 200 400 12 NA
3 400 900 12 NA
1 400 800 13 NA
2 500 700 13 NA
3 300 700 13 NA
Re: Calculations between rows based on conditions
To do this in JMP like fashion, you generally would split your data and then perform the calculation (JMP is Not a Spreadsheet), then join it back or continue with the split data.
But you can use also JSL or Formula to do this calculation, but first consider the splitting option.
Here is one matrix option, but using JMP features is generally easier to understand
cuvette_start = 11;
cuvette_end = 12;
cuvettes = dt[0, "Cuvette"];
// Data is sorted -> we can just take values and make comparison
start_idx = Loc(cuvettes, cuvette_start);
end_idx = Loc(cuvettes, cuvette_end);
// differences
output = J(1, N Rows(dt), .);
output[start_idx] = dt[start_idx, "850 nm"] :\ dt[end_idx, "250 nm"];
dt << new column("R", Numeric, Continuous, Values(output));
If you can rely on the order heavily, you can use formula like this
If(:Cuvette == 11,
	:"850 nm"n / :"250 nm"n[Col Min(If(:Cuvette == 12, Row(), .)) + Row() - 1];
The type of final formula will heavily depend on your real use case (is data sorted "properly", are you looking for more than one value comparison and so on).
Welcome to the Community.
Here is an example of how I would approach your problem
// Separate out the Cuvette==12 rows into a separate data table
// and then join the Pass==Pass rows to the Cuvette==11 rows
// Then calculate the Output column
// Select the Cuvette==12 rows
dt << Select Where( :Cuvette == 12 );
// Create a new subsetted data table with those rows
dt12 = dt << Subset( Selected Rows( 1 ), columns( :Pass, :"250 nm"n ) );
// Change 250 nm column name so when joined back to original table
// it will have a unique column name
dt12:"250 nm"n << Set Name( "Divisor" );
// For alignment reasons, add a new column called Cuvette and set
// it equal to 11
dt12 << New Column( "Cuvette", Set Each Value( 11 ) );
// Join the tables using the Update Platform
dt << Update(
	With( dt12 ),
	Match Columns( :Pass = :Pass, :Cuvette = :Cuvette )
// Create the new Output column
dt << New Column( "Output", Set Each Value( :"850 nm"n / :Divisor ) );
// Remove Divisor column since it is no longer needed
dt << delete columns( Divisor );
// Close the subsetted data table since it is no longer needed
Close( dt12, nosave );
// Remove the Selected RowStates from the data table
dt << clear rowstates;
 Below is a more direct approach, but a far more inefficient method, which yields the same results.  On a large data table this method will be quite slow
	Formula(
		foundRow = [];
		If( :Cuvette == 11,
			curPass = :Pass;
			foundRow = Current Data Table() <<
			get rows where( :Cuvette == 12 & :Pass == curPass );
			If( N Items( foundRow ) > 0,
				:"850 nm"n / :"250 nm"n[foundRow[1]]
