DiCosimoA
Calculation grouped by variable
I would like to find the maximum value from a column, but I need to group the data based on other columns; is it possible using a formula or a script?
As example, I would like to populate a new column with the maximum height, but divided by age, sex and nationality:
Nationality Sex Age Height
ITA M 25 180
USA F 23 180
FRE M 24 168
FRE M 25 201
GER F 23 160
ITA X 23 175
ITA X 24 158
CAN M 25 193
USA F 23 170
SPA F 24 179
SPA X 25 169
GER F 23 163
GER M 24 185
CAN X 25 201
CAN M 23 193
ITA F 24 170
USA F 25 180
FRE X 23 179
FRE F 23 169
GER M 24 163
USA M 25 185
SPA F 23 180
SPA M 24 179
GER M 25 185
GER F 23 201
ITA X 24 193
Thank you in advance.
Re: Calculation grouped by variable
Col Max( :Height, :Age, :Sex, :Nationality )
DiCosimoA
Thank you so much! That's exactly what I was looking for!
