emma_121
Calculating & Positive Response
I have some Consumer Research data, in which the answer set was an agreement scale (Agree Strongly, Agree, Agree Slightly, Disagree Slightly, Disagree and Disagree Strongly). How do I combine the % totals for all the positive respondents (i.e. those that selected any of the Agree answer sets) in JMP?
I have attached an Excel example for reference.
If possible, an interactive explanation would be great.
Thanks!
ledi_trutna
Re: Calculating & Positive Response
There is a column property called Supercategories where you can define the levels of the response that you want to group together into the positive response.  This property is used in the categorical platform when analyzing your survey data.
If you have multiple columns you would like to apply the supercategories property to, define it for one, and use Standardize Attributes to copy the property to the other response columns.
Thierry_S
It looks like you may be able to get what you need by simply creating a new Column with the formula: (Sum (N Agree Strongly, N Agree, N Agree Slightly)/ Total N). You can then format the output as Percent (Column Info > Format > Percent).
Is that you were looking for?
Best,
TS
Thierry R. Sornasse
ledi_trutna
