natalie_
Level V
Calculating Standard Deviation
Hi all.
I have a question about JMP and calculating standard deviation.
From my understanding about statistics, there are different formulas to calculate stand deviation for different types of distribution (normal or gamma for example).  When I am use JMP to calculate standard deviation, does it always assume that my data has a normal distribution?
Byron_JMP
Re: Calculating Standard Deviation
Yes, unless you specify a distribution model.
When I have specific distribution model for a column, I save that as a column property.
http://www.jmp.com/support/help/Fit_Distributions.shtml
Byron_JMP
natalie_
Level V
Thank you and sorry for the delay.
This was very helpful.
