shasheminassab
Calculate Moving R2
How can I calculate R2 between two variables (i.e. columns) in a moving window (e.g., 10 pairs of data at a time)?
Sina
Re: Calculate Moving R2
See this discussion about performing linear regression in a column formula. This approach could be extended to obtain R square or other results.
shasheminassab
Thanks @Mark_Bailey. What is the function to calculate R2 in JSL? (sorry I am new to JSL scripting and couldn't find it online).
ron_horne
I understand.
Here is an example based on the Big Class data table in the Sample Data folder. It fits a moving linear regression with a span of 5. It returns the R square value in each row. You can run this script to see how it works.
// example creates a new column with a moving R square with a span of 5
// for regression of :weight versus :height
dt << New Column( "Moving R Square",
	Numeric,
	Continuous,
	Formula(
		If( Row() > 2 & Row() < (N Row()-1),
			x = J( 5, 1, 1 ) || :height[Index( Row() - 2, Row() + 2 )]`;
			y = :weight[Index( Row() - 2, Row() + 2 )]`;
			sst = Sum( (y - Mean( y )) ^ 2 );
			b = (Inv( x` * x ) * x` * y);
			yhat = x * b;
			sse = Sum( (y - yhat) ^ 2 );
			(sst-sse) / sst;
			Empty()
You can select the part of this script that is within the parentheses after the Formula argument and past that expression into a new column formula in your data table, then change the column names to match your X and Y data columns.
shasheminassab
Thank you @Mark_Bailey and @ron_horne . This was very helpful!!
