ashwint27
Calculate Column Difference for other column levels where lag varies
I have a column :EVENT (character-nominal) with various values.  Also another column :datetime (numeric-continuous).  I have :datetime column sorted ascending.  I am interested in having another column calculate for whenever there is a "CONNECT" event, what is the time difference between it and the last "DISCONNECT" event.  The issue is that the lag can vary between a CONNECT and previous DISCONNECT (see photo below) and I'd also prefer keeping this tall table format.  A solution for datetime sorted-ascending is appreciated, but also not sorted would also be beneficial.
Re: Calculate Column Difference for other column levels where lag varies
You can for example use variable in the formula to store the value of last disconnect
dt = New Table("Untitled",
	Add Rows(12),
	Compress File When Saved(1),
	New Column("E", Character, "Nominal", Set Values({"A", "B", "Disc", "Con", "A", "B", "C", "B", "Disc", "A", "B", "Con"})),
	New Column("T", Numeric, "Continuous", Format("Best", 12), Set Values([0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11]))
dt << New Column("Dif", Numeric, Continuous, Formula(
	If(Row() == 1,
		last_disc = .;
		retval = .;
	If(:E == "Disc",
		last_disc = :T;
		retval = .;
	, :E == "Con",
		retval = :T - last_disc
		retval = .;
	retval;
	Add Rows(12),
	If(Row() == 1,
		last_disc = .;
		retval = .;
	If(:E == "Disc",
		last_disc = :T;
		retval = .;
	, :E == "Con",
		retval = .;
	retval;
ashwint27
This approach worked great, thanks!
You can also use matrices
	Add Rows(12),
events = :E << get values;
times = :T << get values;
discs = Loc(events, "Disc");
cons = Loc(events, "Con");
difs = J(1, N Rows(dt), .);
difs[cons] = times[cons] - times[discs];
dt << new column("difs", numeric, continuous, values(difs));
This does have quite a few assumptions but can be made more robust for all sorts of edge cases (Loc Sorted can be helpful for something like this, sometimes even KDTable/VPTree).
ashwint27
To throw a slight wrinkle into this, there are times where a CONNECT Event may show up a few times before a DISCONNECT Event comes up.  In this case, I'd like the difference to only be calculated on the first CONNECT Event that appears after a DISCONNECT Event.  Is there a slight modification to the script that can accommodate this?  Thanks again for your help.
Here is a modification to @jthi code that should handle this.
	Add Rows(12),
	If(Row() == 1,
		last_disc = .;
		retval = .;
	If(:E == "Disc",
		last_disc = :T;
		retval = .;
		firstCon = .;
	, :E == "Con",
		If(ismissing(firstcon), firstcon=:t);
		retval = firstcon - last_disc
		retval = .;
	retval;
  I suggest you take the time to read the Scripting Guide, available under JMP Help.  Also please take the time to study the code provided by responding Discussion Forum members.  The modifications to Jarmo's script did not require any new scripting knowledge.  It only required some additional logic added to the flow of the script.  It should be a user's goal to be able to make their own enhancements to the scripts
