BrianK
CUSUM Control Chart
hi guys,
If I take the data set from the sample data library "Engine Temperature Sensor.jmp." and run the script below, I detect a shift at datapoint 26. What I would like to do is to modify the script below,so upon a shift detection only, it would automatically do something (example trigger an email, or write to a file ) flagging a shift was detected and on which data point the shift occurred?
Any ideas on how to achieve this?
Thanks
Brian..
CUSUM Control Chart(
	Y( :Y ),
	Sigma( 5 ),
		Dispatch( {"CUSUM Chart"}, "2", ScaleBox, {Min( -10 ), Max( 10 ), Inc( 5 ), Minor Ticks( 1 )} ),
		Dispatch( {"CUSUM Chart"}, "CUSUM Control Chart Plot", FrameBox, {Frame Size( 1136, 644 )} )
Re: CUSUM Control Chart
I'm happy to report - In JMP 16, we added alarm scripts for CUSUM charts. This allows you to trigger warnings or other actions to occur when a shift is detected.
Byron_JMP
Challenge Accepted
I wonder if its possible to use the standard control chart alarm scripts to catch the flag and then launch an action?
Maybe...
Byron_JMP
SWEET!
Thank you. Really looking forward to all the updates in the new version.
