CHISQ.INV.RT
LasersOnSharks
Does JMP have an equivalent to excel's CHISQ.INV.RT function? I need it for FIT rate (reliability) calculations. Thanks in advance!
peng_liu
Re: CHISQ.INV.RT
Use "ChiSquare Quantile" function. See following screenshot to see how the results match.
Notice, the Excel function use right-tail probability, and you need 1 minus that probability for the JSL function.
BTW, I am curious, under what situation, do you need to manually calculate this quantity?
peng_liu
Re: CHISQ.INV.RT
Re: CHISQ.INV.RT
Thank you so much!!
The application is for semiconductor failure rates.
https://www.renesas.com/us/en/document/qsg/calculation-semiconductor-failure-rates
peng_liu
Re: CHISQ.INV.RT
Thanks for letting me know the application and providing the reference.
