Sandra233
Bug Report: Spec Band (Rect) Not Rendered on Variability Chart Problem Description
I'm having trouble with my script. Please help me identify the errors and do modification in my script
1. Issue with spec range: The green specification band (colored rectangle) is not displayed on the Variability Chart.
2. Adding multiple X factors: How should I modify script if I want to include multiple X factors?
Re: Bug Report: Spec Band (Rect) Not Rendered on Variability Chart Problem Description
If there is a bug to report, please contact JMP Support.
And fixing the script (looks like some jsl I have written some time ago), I would assume you have to fix COMBINEX formula
dt << new column("COMBINEX", Character, Nominal, Formula(:TYPE ||Char(:MBB)));
