pickle
Box plot defaults
I am making some box plots and I am wondering about the defaults (and more appropriately, how to change them). Where is it described how JMP chooses the box width (and how can it be changed, to a constant width). Also, is there any way to get the JMP to plot them in numeric order along the x-axis (JMP is plotting the values as 1, 10, 11, 12, 13....2, 3, 4,; I would like them plotted as 1,2,3,4,5,6,7,8,9,10,11,12......)?
ms
Super User (Alumni) ms
Re: Box plot defaults
In the Fit Y by X platform you can set equal box width by deselecting "X Axis Proportional" found under the red triangle -> Display Options.
Box Plots in Graph Builder should have equal width by default.
If your x variable has data type "character", change it to "numeric" to enable numeric ordering of x-levels.
Alternatively, you can use the Value Order column property if x includes categories (e.g. "Other") that cannot be represented numerically.
