geof
Filter a string using "like" ?
Using the example below, how could I filter all the names starting like "M"
Is it possible to use "like" or something similar ?
Data Filter( Add Filter(
        columns( :name ),
        Where( :name like M* )       /// Not working of course !
Thanks for you help
open("$sample_data\Big class.jmp");
Graph Builder(
Size( 454, 472 ),
Show Control Panel( 0 ),
Variables( X( :age ), Y( :weight ), Y( :height ), Overlay( :name ) ),
Elements( Position( 1, 1 ), Points( X, Y, Legend( 3 ), Jitter( 1 ) ) ),
Elements( Position( 1, 2 ), Points( X, Y, Legend( 4 ), Jitter( 1 ) ) )
Jeff_Perkinson
Re: Filter a string using "like" ?
Unfortunately, the Data Filter in JMP doesn't support partial string matches. You must match whole values.
However, you can find all the values that match your partial string and then use that list in your call to the data filter.
dt = open("$sample_data\Big class.jmp");
Graph Builder(
Size( 454, 472 ),
//create a list of the unique names
summarize(nameslist=by(:name));
//create a matrix to hold the locations of the strings that match your pattern
x=[];
//loop over list of names storing the matches in x
For( i = 1, i <= N Items( nameslist ), i++,
  If( Starts With( nameslist[i], "M" ),
// "|/" is the matrix vertical concat operator
  x = x |/ i;
dt << Data Filter(
  Location( {848, 24} ),
  Add Filter(
  columns( :name ),
  Where( :name == nameslist[x] ),
-Jeff
mikekutz
I think the filter function you are looking for is:
starts with( name, "M" )
MK
sasguy
Your options to mimic a like statement are as follows:
Where( starts with (:name, "M" )) /* Name starting with M */
Where( ends with (:name, "M" ))  /* Name ending with M */
Where( contains (:name, "M" ))    /* Name contains M */
Jeff_Perkinson
Graph Builder(
Size( 454, 472 ),
x=[];
  x = x |/ i;
dt << Data Filter(
  Add Filter(
  columns( :name ),
-Jeff
geof
Thanks for your help
Geof
