jnikkel
Bivarate Linear Fit of multiple Regressions - Scripting a Combined Data table from Parameter Estimates
I have been working on scripting some data analysis done in JMP with multiple tabulate, Y by X Bivarate Fit, and split table steps. I have been able to generate scripts for everything except step where I right click in a Parameter estimates TableBox from the Fit Group report and select 'Make Combined Data Table"
Any suggestions for how to accomplish this?
My Script language is here:
dt = Open( "data file directory" );
obj = dt << Tabulate(
	Add Table(
		Column Table( Analysis Columns( :KT3, :Log Age, :k31, :N1 ), Statistics( Mean ) ),
		Row Table( Grouping Columns( :Batch No., :Age ) )
obj << Make into Data Table;
New Window( "",
	V List Box(
		Fit Group(
			Bivariate(
				SendToByGroup( {:Batch No. == "By Variable 1"} ),
				SendToByGroup( {:Batch No. == "By Variable 1"}, Y( :Name( "Mean(KT3)" ) ) ),
				SendToByGroup(
					{:Batch No. == "By Variable 1", Platform Index( 2 )},
					Y( :Name( "Mean(k31)" ) )
				SendToByGroup(
					{:Batch No. == "By Variable 1", Platform Index( 3 )},
					Y( :Name( "Mean(N1)" ) )
				SendToByGroup( {:Batch No. == "By Variable 2"}, Y( :Name( "Mean(KT3)" ) ) ),
				SendToByGroup(
					{:Batch No. == "By Variable 2", Platform Index( 2 )},
				SendToByGroup(
					{:Batch No. == "By Variable 2", Platform Index( 3 )},
				SendToByGroup( {:Batch No. == "By Variable 3"}, Y( :Name( "Mean(KT3)" ) ) ),
				SendToByGroup(
					{:Batch No. == "By Variable 3", Platform Index( 2 )},
				SendToByGroup(
					{:Batch No. == "By Variable 3", Platform Index( 3 )},
				SendToByGroup( {:Batch No. == "By Variable 4"}, Y( :Name( "Mean(KT3)" ) ) ),
				SendToByGroup(
					{:Batch No. == "By Variable 4", Platform Index( 2 )},
				SendToByGroup(
					{:Batch No. == "By Variable 4", Platform Index( 3 )},
				SendToByGroup( {:Batch No. == "By Variable 5"}, Y( :Name( "Mean(KT3)" ) ) ),
				SendToByGroup(
					{:Batch No. == "By Variable 5", Platform Index( 2 )},
				SendToByGroup(
					{:Batch No. == "By Variable 5", Platform Index( 3 )},
				SendToByGroup( {:Batch No. == "By Variable 6"}, Y( :Name( "Mean(KT3)" ) ) ),
				SendToByGroup(
					{:Batch No. == "By Variable 6", Platform Index( 2 )},
				SendToByGroup(
					{:Batch No. == "By Variable 6", Platform Index( 3 )},
				SendToByGroup( {:Batch No. == "By Variable 7"}, Y( :Name( "Mean(KT3)" ) ) ),
				SendToByGroup(
					{:Batch No. == "By Variable 7", Platform Index( 2 )},
				SendToByGroup(
					{:Batch No. == "By Variable 7", Platform Index( 3 )},
				SendToByGroup( {:Batch No. == "By Variable 8"}, Y( :Name( "Mean(KT3)" ) ) ),
				SendToByGroup(
					{:Batch No. == "By Variable 8", Platform Index( 2 )},
				SendToByGroup(
					{:Batch No. == "By Variable 8", Platform Index( 3 )},
				X( :Name( "Mean(Log Age)" ) ),
				Fit Line( {Line Color( {212, 73, 88} )} ),
				By( :Batch No. )
Report( Fit Group[1] )["Parameter Estimates"][Table Box( 3 )] << Make Combined Data Table;
Re: Bivarate Linear Fit of multiple Regressions - Scripting a Combined Data table from Parameter Estimates
To get what you want, change
Bivariate(
to
Biv = Bivariate(
and change
Report ( Fit Group[1] ) ["Parameter Estimates"][Table Box( 3)] << Make Combined Data Table;
to
Report ( Biv[1] ) ["Parameter Estimates"][Table Box( 1)] << Make Combined Data Table;
Bivariate(
to
Biv = Bivariate(
and change
to
jnikkel
I was so close, thank you!
