Where do you have your limits saved?
If your starting data is like this:
I would stack it by Measurements (Tables/Stack) and then add limits to the new table (maybe with Join, depends where and how you are getting the limits). Then create a formula to check if value in data is out of spec
and after this you can start playing around with different options in graph builder
Other option could be to use Spec Limits column properties to set the limits to your original data and then use Process Screening platform:
