SDF1
Best way to convert UTC time format to numeric
Hi All,
 (JMP 17 & JMP 18EA)
  I have some XML data with a column that contains a time stamp, but the data format is not very compatible for what I'd like to do with it in JMP.
  The data is in the following UTC format yyyy-mm-ddThh:mm:ss.SSSZ, where the usual meanings are applied to the abbreviations. Here, there is actually a "T" after dd, and a Z after ".SSS", and the .SSS stands for milliseconds, there are no spaces. Unfortunately, JMP doesn't appear to have a built-in date format that can handle this well, even though it does have a similar format, but without the milliseconds and Z; so JMP can handle time in the format yyyy-mm-ddThh:mm:ss.
 The only way I can get JMP to parse the UTC date/time is by using the Substr() command in a column formula, remove the column formula, and then change the data type and format. This won't be too difficult to script, but just wondering if someone else has a more efficient way of handling date/time data in this unusual format.
  Or, does anyone know if JMP is considering to include this UTC time format to make conversion easier?
Thanks!,
DS
Re: Best way to convert UTC time format to numeric
You can get quite far by using Format Pattern with <YYYY><-><MM><-><DD><'T'><hh24><::><mm><::><ss>Z
date_str = "2022-12-23T14:54:50.123Z";
x = Informat(date_str,
	"Format Pattern",
	"<YYYY><-><MM><-><DD><'T'><hh24><::><mm><::><ss>Z"
show(x, Second(x));
(might have to do some rounding)
	"Format Pattern",
show(x, Second(x));
SDF1
Hi @jthi ,
  Excellent, that is much more efficient at doing the conversion, thank you!
Thanks!,
DS
Binyamin
Thanks, saved the day, had the same issue and because I put the Z between a set of < > it didn't work.
