NTPSV113
Bar plot - how to get the outline
How to get the bar to show completely instead of the line as seen in the picture below.
All the other files I have work fine.
This one was created by copy pasting selected data instead of opening the data file.
Thank you for your time.
Re: Bar plot - how to get the outline
@NTPSV113
It looks like your y-axis is Nominal and not Continuous. When you cut and paste the data, there may have been a text character in your column, so the entire column was coded as Nominal. If you change the modeling type to Continuous, you might get the bar graph you are looking for.
-Scott
I can not see your control section of the graph, so it is hard to determine the issue.
Also, what version of JMP are you using, and what operating system?
@NTPSV113
-Scott
