TWE
TWE
Bar chart Label size/position
how can I adjust the size and/or position of the label e.g. "label by value" in a stacked bar chart? In terms of the screenshot below the label of the green area is missing. I think because of the height but how can I still show it?
Thanks
Phil_Kay
Re: Bar chart Label size/position
I can't find a way to do this. I think that there must be a rule that if the label is bigger than the bar, it will not be displayed. It would obviously get very messy if you had multiple such bars within the same stack.
I can only suggest using a different visual (side by side bar) or providing a tabulation alongside the stacked bar plot for people to refer to for the figures. You should know that you can also hover on the chart to get the values.
TWE
TWE
Thanks for the helpful explanation and hints.
