See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
Bar Graph (Negative Values)
CiaranMcCarron
16
Does anyone know how to plot negative values on a bar chart? It is quite easy on Excel but I cant seem to see how it is done on JMP.
Re: Bar Graph (Negative Values)
Here is a simple data table
and if you drag the Value column to the Y axis, and the Group column to the X axis, and select the bar chart icon, here is what you get
Thanks very much, I was loading it into graph builder, this works perfectly.
Regards
Ciarán
