How can I change chart labels to bold font? I have every font in preferences set to bold, yet chart labels remain normal type. I have JMP 18 installed.
Graph Builder has a few options to customize the fonts and styles. Are you using Graph Builder, or another platform?
To set a Preference to always use bold type in graph or axis titles, that can be set under File > Preferences > Fonts > Axis Title (or Graph Title).
If you only want to set this font style in the current analysis: in Graph Builder, right-click directly on the title text and select "Font".
Optionally, hold Ctrl while doing this to apply the change to all similar titles in the window.
Once the fonts look the way you like, you can save this as a Platform Preset by clicking on the small star icon in the upper right corner of the graph builder window. This can then be applied to future analyses.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '875291' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '875291') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '875291') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
