Sure, Splitting without the group is doing it in a literal fashion by row and is not aware that Item has a missing component for category. Group forces level to separate out by Item for each category by taking a look at Item first then Category.
From online help (https://www.jmp.com/support/help/en/18.2/?os=mac&source=application#page/jmp/split-columns-in-data-t...
Group
Specifies a Group variable when you want your data to be split within each group of the selected variable. Each group results in a row in the output table. You must also specify the required variables, Split By, and Split Columns.
Note: If the variable that you want to group by contains unequal groups or is in a random order, specifying it as the Group variable ensures that your data is restructured properly, and any missing values are assigned in the appropriate places.
Otherwise you would have to put in an extra row and define Category and Item but leave Level blank for that row.
Hope that helps.
Chris Kirchberg, M.S.2
www.jmp.com
