Hi @frankderuyck,
As @Phil_Kay mentioned it, Mixture designs are quite different from other designs (like factorial designs), as the factors are not independent : changing the level of a mixture factor has an impact on others, so mixture factors are correlated.
Also, the emphasis of this type of design is more on predictivity and optimization than screening/statistical significance.
Last, you seem to have chosen a model-based mixture design (not a Space-Filling approach), so you already have assumed a possible complete model you would like to investigate.
For these 3 reasons, it makes more sense in the analysis to start from the full model with the possible terms you have assumed in the design creation, and start removing terms in the model (except main effects), based on the predictive performance of the model (RMSE for example), NOT on individual p-values/logworth of each term (because of multicollinearity/correlation among mixture factors, no intercept in this type of model, p-values/logworth are not a valid metric for model selection).
If you want to use a Stepwise approach to "automatize" the model selection, you can use Backward Stepwise Regression, with an information criterion (AICc or BIC, to balance accuracy vs. complexity of the model) as stopping rule.
I hope this additional answer will help you,
Victor GUILLER
L'Oréal Data & Analytics
