mkiesz
Using interaction effects in JSL fit model
Hi Community,
I'm try to create a script that dynamically creates a model with main effects and interactions.
For instance, I might have a subset of effect columns defined by the following:
all_cols = Current Data Table () << Get Column Names(String);
effect_cols = all_cols[3::8];
And then I build a series of models reducing the effect_cols.
Subsequently, I consider interaction terms. However, I'm having trouble building a list of column names or column references for interaction terms.
I've tried something like this:
if(length(effect_cols) > 1,
	interaction_effects = {};
	for(i = 1, i < length(effect_cols), i++,
		for(j=i+1,j<= length(effect_cols), j ++,
			inter_tmp = effect_cols[i] || "*" || effect_cols[j];
			interaction_effects = insert(interaction_effects,inter_tmp);
and building it into a model with this:
Fit Model(
		Y( :"Result"n ),
		Effects(
			concat(effect_cols,interaction_effects),
		Emphasis( "Effect Screening" ),
		Run(	),
However, this consistently gives an error and my other attempts at using parse() and eval() are not working.
Any help is much appreciated.
Thank you
Re: Using interaction effects in JSL fit model
If I remember correctly I have tried with something like this
dt = Open("$SAMPLE_DATA/Tiretread.jmp");
effect_cols = {"SILICA", "HARDNESS", "SILANE", "SULFUR"};
terms = {};
For Each({first_term, idx}, effect_cols[1::N Items(effect_cols) - 1],
	For Each({second_term}, effect_cols[idx+1::N Items(effect_cols)],
		cur_interaction = Substitute(Expr(_firstterm_*_secondterm_),
			Expr(_firstterm_), NameExpr(AsColumn(first_term)),
			Expr(_secondterm_), NameExpr(AsColumn(second_term))
		Insert Into(terms, Name Expr(cur_interaction));
fitm = dt << Fit Model(
	Y(:ABRASION),
	Effects(Eval(terms)),
	Personality("Standard Least Squares"),
	Emphasis("Effect Screening")
ron_horne
Hi @mkiesz ,
did you try  to script the stepwise platform? it may have some of your model selection criteria built in.
terms = {};
	Y(:ABRASION),
