Fabrice_L
Background color
I'm exporting JMP results to pdf, and I would like to change the usual background color of these output (so to be clear, the color behind "Distributions" for example in the attached image). In JMP preferences -> Styles, I can change some elements of the output, like the background color of the page, but not this element (at least I have not found how to do it). Can somebody help ? Thanks a lot.
Fab.
Ps: I'm on JMP15.
Ps: Is there a way to change (forever) other colors, like the green color in the graph attached ?
Re: Background color
There are a number of ways to change colors of graphs.  Whenever the graph is created, you can right click on the space and you will have to option to change color.  If you want to change the color of distributions forever, go to Preferences>Platforms>Distribution, select the Histogram color box and select the color you want.  In preferences there is also the option to change graph background colors in the Colors section, see below
Fabrice_L
Thanks for the reply. I did not know how to change permanently a color used in a certain analysis, so thanks for this. I have seen the possible change of the background color in Preferences -> Style ("Windows background color"), this works, but I still cannot find a way to change the title background color.
