gianpaolo
Autosave Timeout
Good Morning Community
in JMP Preferences seems that is possible to set Autosave Timeout (in order to prevent opened file from crash accidents),
but i dont understand very well where this files are and how are saved.
Somone can better explain me how it works?
thanks in advance
Gianpaolo
Gianpaolo Polsinelli
Re: Autosave Timeout
The files are located where ever you saved them in the first place. This feature simply saves them at given intervals. It is the same result as selecting File > Save for the current data table but occurs automatically for all open data tables.
gianpaolo
Thank you markbailey,
perfect...
So, i saved a file in a specific location... i did some file modification, i didnt saved the modified file...at the end (after 5 minutes (autosave timeout 5 in my work station) I have simulated a JMP crash ...
when i re-opened JMP, and i tried to open the file.. i have found the last modifiations !
