blue1994
Automatically save the file to folder
Hi, does anyone know if I select the any file from desktop,eg: CSV, after i open that file,  it can automatically save into the working folder by using JSL?
Thanks
Re: Automatically save the file to folder
Here is a simple script that does what you want
names default to here( 1 );
// Pick the file to open
myPath = Pick File("tdisplayed text string", "path to initial folder");
dt = open(myPath);
dt << save("path to work directory.jmp);
Details on Pick File, Open and Save functions are found in the Scripting Index:
     Help==>Scripting Index
