mthacker477
Automate Reference Line Based on Column Data
Hello, I am very new to JSL and am struggling to think of a way to automatically create multiple reference lines in a graph based on values in a specific column. Currently, I am graphing one variable (:Signal) on the Y axis, and three variables (:Zone, :Target, and :Condition) on the X axis. Each (:Target) variable has a specific (:historical signal) and I would like to find a way to automatically graph a (:Target)'s (:historical signal) as a reference line. The code I have is done by manually adding the historical signal value via h line(), but ideally the script would add a reference line for each (:target) based on its corresponding historical signal. Thank you!
Variability Chart(
	Y( :Signal ),
	X( :Zone, :Target, :Condition ),
	Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
	Show Range Bars( 0 ),
	Show Cell Means( 0 ),
	Std Dev Chart( 0 ),
	Mean Diamonds( 1 ),
		Dispatch(
			{"Variability Chart for Signal"},
			"Variability Chart",
			FrameBox,
			{Frame Size( 969, 240 ),
			Add Graphics Script(
				2,
				Description( "" ),
				Pen Color( "RED" );
				//Target 2
				H Line( 0, 2, 234 );
				//Target 3
				H Line( 2, 4, 670 );
				//Target 1
				H Line( 4, 6, 463 );
Re: Automate Reference Line Based on Column Data
All that needs to be done, is to figure out how to get the values and the order, and then generate the required JSL.  Here is a simple example that should give you a start in the right direction to create your final script.
// Find the number of targets and get the means
Summarize( dt, targs = by( :Zone, :Target ), targMeans = Mean( :Historical Signal ) );
vc = Variability Chart(
	Y( :Signal ),
	Std Dev Chart( 0 ),
	Mean Diamonds( 1 )
// Create the JSL to submit to generate the Target Lines
theExpr =
"Report( vc )[FrameBox( 1 )] << add graphics Script(
		Description( \!"\!" ),
		Pen Color( \!"RED\!" );";
For( ii = 1, ii <= N Items( targMeans ), ii++,
	theExpr = theExpr || "H Line( " || Char( (ii - 1) * 2 ) || "," || Char( (ii - 1) * 2 + 2 )
	 || "," || Char( targMeans[ii] ) || ");";
Eval( Parse( theExpr ) );
Given your current data structure, here is one way of automating your Historical Signals
targ1 = Mean( :Historical Signal[dt << get rows where( :Target == "Target 1" )] );
targ2 = Mean( :Historical Signal[dt << get rows where( :Target == "Target 2" )] );
targ3 = Mean( :Historical Signal[dt << get rows where( :Target == "Target 3" )] );
Variability Chart(
	Y( :Signal ),
	Std Dev Chart( 0 ),
	Mean Diamonds( 1 ),
		Dispatch(
			FrameBox,
			{Frame Size( 969, 240 ), Add Graphics Script(
				2,
				Description( "" ),
				Pen Color( "RED" );
				//Target 2
				H Line( 0, 2, targ2 );
				//Target 3
				H Line( 2, 4, targ3 );
				//Target 1
				H Line( 4, 6, targ1 );
mthacker477
Hey txnelson, thank you so much for your response, this is almost exactly what I am looking for! The only other thing I am wondering is if it is possible to have the h line() code match with its corresponding :Target instead of having to manually enter the coordinates on the graph. In the future, I am going to be adding differing amounts of targets and they will not always be in the same order.
	Y( :Signal ),
	Std Dev Chart( 0 ),
	Mean Diamonds( 1 )
theExpr =
