SpannerHead
Auto Scaling
Following up with this.
https://community.jmp.com/t5/Discussions/Automatic-Scaling-Matching-X-and-Y-Axes/m-p/762890#M94321
I discovered a flaw in the script whereby excluded rows are not plotted but still factor in the graph scaling.  I need a way to eliminate those from y_there and x_there somehow.
dt << Clear Column Selection();
colList = dt << get column names( string );
check_list = {"VT", "ID", "DI", "IK", "GM"};
New Window( "Select Variables",
	<<Modal,
	<<On Validate( window:validated ),
	window:enable function = Function( {},
		{Default Local},
		X = window:lbMajor << Get Selected;
		Y = window:lbMinor << Get Selected;
		If( N Items( X ) & N Items( Y ) & X != Y,
			window:validated = 1,
			window:validated = 0
		window:ok button << Enable( window:validated );
	H List Box(
		V List Box(
			Text Box( "Select X Variable" ),
			window:lbMajor = List Box(
				check_list,
				<<Set Max Selected( 1 ),
				enable function
		V List Box(
			Text Box( "Select Y Variable" ),
			window:lbMinor = List Box(
				check_list,
				enable function
	H List Box(
		window:ok button = Button Box( "OK",
			If( window:validated,
				Print( "Processing with X: " || Char( X ) || ", Y: " || Char( Y ) );
				Window( "Select Variables" ) << Close Window;
				Beep();
				Show( "Invalid Selection" );
				{window:lbMajor, window:lbMinor} << Select;
				window:lbMajor << Inval << Update Window;
				Wait( 0.25 );
				{window:lbMajor, window:lbMinor} << DeSelect;
				Wait( 0.25 );
				Wait( 0.25 );
			<<Enable( 0 )
		Button Box( "Cancel", Throw( "!Canceled Analysis" ) )
If(
	X[1] == "VT", Xparam = "VT",
	X[1] == "ID", Xparam = "ID",
	X[1] == "DI", Xparam = "DI",
	X[1] == "IK", Xparam = "IK",
	X[1] == "GM", Xparam = "GM"
If(
	Y[1] == "VT", Yparam = "VT",
	Y[1] == "ID", Yparam = "ID",
	Y[1] == "DI", Yparam = "DI",
	Y[1] == "IK", Yparam = "IK",
	Y[1] == "GM", Yparam = "GM"
Show( Xparam );
Show( Yparam );
For( i = 1, i <= N Cols( dt ), i++,
	If(
		Contains( Munger( Head Name( As Namespace( colList[i] ) ), 0, 2 ), Xparam )
		 & Contains(
			"% Delta From Target"
		Column( colList[i] ) << Set Selected( 1 )
target = dt << get selected columns();
found_list = {};
Show( target );
New Window( "Compilation",
	For( j = 1, j <= N Items( target ), j++,
		Notes = target[j] << Get Property( "Notes" );
		If(
			Contains(
				Munger( Head Name( As Namespace( target[j] ) ), 0, 2 ),
				Xparam
			Connected = Substitute( Head Name( As Namespace( target[j] ) ),
				Xparam, Yparam
			Insert Into( found_list, Connected );
			Try(
				biv = Bivariate(
					Y( Column( dt, found_list[j] ) ),
					X( Column( dt, target[j] ) ),
					Automatic Recalc( 1 ),
						Dispatch(
							"Bivar Plot",
							FrameBox,
							{Frame Size( 470, 470 ),
							Add Text Annotation(
								Text( "Category: " || Notes ),
								Fixed Size( 0 ),
								Filled( 0 ),
								Font( "Segoe UI", 10, "Bold" )
							), Add Graphics Script(
								2,
								Description( "" ),
								Transparency( 0.5 );
								Pen Color( "Black" );
								Fill Color( "Red" );
								Oval( -100, -100, 100, 100, 1 );
								Fill Color( "Green" );
								Oval( -90, -90, 90, 90, 1 );
								Fill Color( "Blue" );
								Oval( -80, -80, 80, 80, 1 );
								Line( [-110 0 110], [0 0 0] );
								Line( [0 0 0], [-110 0 110] );
								Oval( -80, -80, 80, 80 );
								Oval( -90, -90, 90, 90 );
								Oval( -100, -100, 100, 100 );
				ms = Report( biv )[FrameBox( 1 )] << Find Seg( Marker Seg( 1 ) );
				xs = ms << Get X Values |/ 110;
				ys = ms << Get Y Values |/ 110;
				x_there = Loc( !Is Missing( xs ) );
				y_there = Loc( !Is Missing( ys ) );
				ind = Associative Array( x_there );
				ind << Intersect( Associative Array( y_there ) );
				ind = Matrix( ind << Get Keys );
				xs = xs[ind];
				ys = ys[ind];
				val = Max( Max( Abs( xs ) ), Max( Abs( ys ) ) );
				xaxis = Report( biv )[AxisBox( 1 )];
				yaxis = Report( biv )[AxisBox( 2 )];
				xaxis << Min( -1 * val ) << Max( val );
				yaxis << Min( -1 * val ) << Max( val );
Help appreciated.
Slán
SpannerHead
Re: Auto Scaling
If marker segment still has those rows but excluded, you should be able to use them in similar manner as you would for values you get from columns. And if they aren't even there, then there should be nothing to worry about. If necessary you could also utilize << Get Row Numbers with marker segment if it is available.
Also maybe you could just utilize the columns, values stored in those and ignore marker segment as you know the column names.
SpannerHead
Re: Auto Scaling
Jarmo
I modified the script with your suggestions and it works except in a very isolated case where the data has an odd interdigitisation resulting from a transpose.
	<<Modal,
		{Default Local},
	H List Box(
		V List Box(
				check_list,
				enable function
		V List Box(
				check_list,
				enable function
	H List Box(
				Beep();
				Wait( 0.25 );
				Wait( 0.25 );
				Wait( 0.25 );
			<<Enable( 0 )
If(
If(
Show( Xparam );
Show( Yparam );
	If(
		 & Contains(
non_excluded_rows = dt << get rows where(!Excluded());
found_list = {};
Show( target );
		If(
			Contains(
				Xparam
				Xparam, Yparam
			Try(
				biv = Bivariate(
						Dispatch(
							"Bivar Plot",
							FrameBox,
								Fixed Size( 0 ),
								Filled( 0 ),
								2,
								Description( "" ),
				x_there = Loc( !Is Missing( xs[non_excluded_rows] ) );
				y_there = Loc( !Is Missing( ys[non_excluded_rows] ) );
				xs = xs[ind];
				ys = ys[ind];
				val = Max( Max( Abs( xs|/ 110 ) ), Max( Abs( ys|/ 110 ) ) );
Slán
SpannerHead
Re: Auto Scaling
You can "pre-filter" your values, for example by getting non-excluded rows first
dt = open("$SAMPLE_DATA/Big Class.jmp");
dt << Select Rows(Index(7, 11)) << Hide and Exclude(1);
m = Column(dt, "height") << get values;
valid_m = m[non_excluded_rows];
N Items(valid_m);
show(valid_m, N Items(valid_m));
SpannerHead
Re: Auto Scaling
Nice script as usual!  Some useful things for sure.  Because my original script is not operating on columns directly and I'm using an associative array (I'm new to those) I can't obviously see where to interrupt my code to make the modification?
Slán
SpannerHead
Re: Auto Scaling
SpannerHead
Re: Auto Scaling
Jarmo
	<<Modal,
		{Default Local},
	H List Box(
		V List Box(
				check_list,
				enable function
		V List Box(
				check_list,
				enable function
	H List Box(
				Beep();
				Wait( 0.25 );
				Wait( 0.25 );
				Wait( 0.25 );
			<<Enable( 0 )
If(
If(
Show( Xparam );
Show( Yparam );
	If(
		 & Contains(
found_list = {};
Show( target );
		If(
			Contains(
				Xparam
				Xparam, Yparam
			Try(
				biv = Bivariate(
						Dispatch(
							"Bivar Plot",
							FrameBox,
								Fixed Size( 0 ),
								Filled( 0 ),
								2,
								Description( "" ),
				xs = xs[ind];
				ys = ys[ind];
Slán
SpannerHead
