nikles
What is the difference between <
Hi.  I'm curious if any can tell me what is the difference between the <<Sib and <<Next commands?  I'm designing a gui and I've noticed both commands will return the display box that immediately follows the current db.  Do they do anything differently, or can they be used interchangeably?
hogi
Level XIII
Re: What is the difference between <
There are cases where it's the same. But for the last child of a parent,
<< sib will return empty() and << next will walk to the next level:
// the same:
New window("v1", mainLB = HList box(x = V list box( tb1 = Text Box("v1"), tb2=Text Box("2") ), tb3=text box ("  3")));
wait(0);
(current report()[TextBox(1)]  << next()) << select;
New window("v2", mainLB = HList box(x = V list box( tb1 = Text Box("v2"), tb2=Text Box("2") ), tb3=text box ("  3")));
wait(0);
(current report()[TextBox(1)] << sib()) << select;
// << next walks to the next level and returns tb3
New window("v3", mainLB = HList box(x = V list box( tb1 = Text Box("v3"), tb2=Text Box("2") ), tb3=text box ("  3")));
wait(0);
(current report()[TextBox(2)]  << next()) << select;
// << sib returns Empty - and select will fail
New window("v4", mainLB = HList box(x = V list box( tb1 = Text Box("v4"), tb2=Text Box("2") ), tb3=text box ("  3")));
wait(0);
(current report()[TextBox(2)] << sib()) << select;
hogi
Level XIII
// the same:
wait(0);
wait(0);
wait(0);
wait(0);
nikles
Thanks @hogi .  Makes sense.
